Hi All
I'm making a ball turning jig. So I will have one part spinning on top of another part with an axle upnthe middle of the both of them.
Since it's a ball turning jig laying horizontal I imagine I use radial bearings as the load moves outward from the axle, not along the axle. With that said I am more focused on the top and bottom pieces. Do their horizontal plains touch? Does the top horizontal plain "float" slightly above the bottom horizontal plain as it rests on exposed ball bearings? The bearings I have now are the enclosed two-ring radial bearings. However, it looks like both the inner and outter rings are at the same height, which makes me think when they are recessed in but sandwiched between the two plates that they would not turn. I envision only exposed ball bearings allowing the sandwiching of the two plates.
Your thoughts?
Your thoughts?
