I have a long term goal of building a nice sized vertical mill, 500mm x 300mm x 300mm capacity, about 20" x 12" x 12" for the metric impaired and throughout the design and research phase I've come to the conclusion that I'm going to need to build a crude metal sharper first. I've been designing the metal shaper based loosely on Gingery's but I don't like the Gib setup, I'd rather use a tapered gib, however I'm not sure I can make a good tapered seat for the gib with the tools I have on hand. So I just wanted to float this idea and seek advice from those more experienced than me.
Does the idea of using a split 2 part tapered gib make any sense, ie the gib seat would be true to the slide and two tapered gibs would stack to form a rectangle which can be made thicker or thinner by sliding one past the other, one end would be seated against a stop and the other end could be adjusted with a screw? Or do you think in the long run it'd be better to just try to use a traditional tapered gib and try to make the gib seat angle? I've never heard of this but my exposure is fairly limited.
Background
I have access to a combo lath/mill machine with some tooling, but nothing exotic and basic hand tools
I'm a 100% hobbiest and quite new
I'm aware of how ambitious this project is
I'm not expecting to save any time or money, or gain any reasonable advantages by building my own machine, I'm only doing it to see what I can achieve.
Background
