- Dec 2, 2016
- 254
So my central machinery 12x36 Lathe has a taper when cutting. I am trying to make a new cylinder barrel for my 1954 TWN Super Tessy and the .003 over 6" is not helping. Anyways when I did my two collar test I was getting about that over 6". I tried adjusting with shims underneath the foot.
First I started off with a .01 shim and had no change. Then I gradually increased it up to .06" still with no change. I finally found a wedge and tried that. Turns out my stand was just pulling off the floor so I loosened everything up again and figured if I want to get the twist back out of the ways best bet would be to anchor the stand to the floor.
I decided then to borrow the test bar from work that fits into the collar for my headstock. This also shows a .006" taper over about a foot. I then mount my chuck and flip the test bar and get about the same.
So is it safe to safe my headstock will need adjustment first and foremost.
Here are the steps I think I should take before the 2 collar test.
Take the rubber mounted feet that were put on the lathe off and use HD bolts to level the cabinets to the to the floor.
Level the lathe with a machinist level to the best I can get.
Loosen four allen heads that hold the headstock and tap it in to indicate zero on the test bar.
Then take to the 2 collar test and start shimming. Maybe leave it under tension for a few hot and cold days and retest. If not moving then anchor cabinets to the floor.
