- Jul 28, 2017
- 2,519
Due to some questions I had about sharpening drills using the Vevor M13A drill sharpening tool I recently purchased, I decided to do some modelling using openSCAD. Its linear_extrude() function includes a "twist" parameter that can be used to generate helical forms -- like the flutes in a drill. OpenSCAD has boolean operators that can subtract one shape from another, which is exactly what's needed to create the flutes, and then a "grinding wheel" type surface to produce the cutting lips.
The biggest question in my mind was how a drill's cutting lips are drawn as straight, despite the fact that the cutter face is a section of a (twisted) cylinder. I wasn't sure if all the drawings I found on the web were factually correct or not.
It took a bit of work to figure out the geometry so I could properly specify the helix' twist factor -- the linear_extrude just expects the number of degrees the extruded form is rotated, over the specified length of the extrusion. So a bit of math was needed to do the conversions. Another pair of variables that ultimately I was unable to find were also related to the flutes -- the diameter of the helix, and its distance from the drill's center. I basically played around with some values until I got some results that looked about right. I own and used Machinery's Handbook volume 26 to get as much info as I could, but it was surprisingly light in the very specific information I was looking for.
Anyway, after doing a lot of experiments I have some conclusions regarding my original concern. It appears that the form of the cutting lips can range from a very non-straight shape to a fairly-straight shape, but it can't ever be absolutely straight. Increasing the diameter of the disk that forms the helix helps to straighten-out the curve of the cutting lips, but at the expense of reducing the overall width of the lips. The problem is that this reduces the drill's rigidity in the radial direction so it might have a greater tendency to snap under a large load. Like many real-world situations, there's a tradeoff involved.
Here's a photo showing one of my "studies" done with one selection of helix radius and diameter. It looks a lot like the physical drills I have.
The "grind" used to accomplish this wasn't done by modelling fixtures that rotate the drill lips across the grinding wheel. It was done by reproducing the result of a linear traverse of the drill across the (flat) plane of a grinding wheel. Like the lip of a cup-style grinding wheel. The grinding radius created by a rotating-style grinding tool can also be reproduced with openSCAD but I haven't quite gotten my head around the geometric considerations yet. It would be the difference between a pair of cylinders rather than flat planes. With all the correct angles, of course.....
