- Sep 26, 2020
- 81
So I bought a enco turret lathe it is a Lht-25b. It needs a lot of clean up but the price was basically scrap price. I seem to be hitting walls at every turn so I figured I would come here and try and get some help.
The first thing is the collet closer. It would not budge. I tried to put a collet in and couldn’t get it to screw in. After getting the collet tube out I think this piece should move?
I have the manual for this machine but it doesn’t really clear this up. The handle has 2 shoes that push on the circled part but I can not get it to budge.
I also got a pile of tooling with it(I’m sure it will not be enough though) and one item was a geometric die head. This I can also not get to budge. I tried closing the chasers in the way I thought it should work but same problem almost no movement except a little vertical if I pull.
I don’t see how to take it apart to clean it up but I am ok with doing that if someone knows how.
