- Jan 14, 2016
- 86
My name is Ken and I'm so green I make grass look yellow. I have a used 7x14 microlux lathe that I bought several months ago it was an impulse buy and now I find myself facinated with it and working on tooling it up. I have several projects i n mind for my other hobby lapidary. The first project I have in mind is making stainless steel shafts for grinding and polishing drums. The through hole in the spindle will only accept up to 13/16 stock which will limit me to 3/4" and less shafts(which is fine) unless I turn between centers which limits me to less than 14 inches when you take into count the lathe dog. My thoughts are that if I can pass the work through the head stock I can gain a few more inches hopefully around 20" total. This would mean that I would have to turn it in two sections I have a feeling it may be hard to get it uniform the entire length this way before I do it stainless is pretty pricey, can you give me any tips on how to do it right?
