I just finished building a ball turning attachment to mount on the cross slide of my 12" Craftsman lathe. My first attempt to turn a ball turned out less than I expected. I need some assistance in the proper way to set up the tool to make the cuts. Oh, the tool cut great, was centered perfectly,but the radius did not turn out correctly. I had trouble getting the tool to clear the stock on the left side cuts, maybe the material needs to be relieved so to provide tool clearance when it rotates, not sure.
So could a forum member lay out the steps for proper set up, say for turning a 1" ball from 1.25" stock.
Thanks
Thanks
