- Dec 30, 2014
- 259
Hi guys,
I am turning down some cold rolled steel and having trouble with it wanting to crawl up on the tool. I am starting with 3/16" rod and only need to take off about .025". If I try to take it all in one pass it crawls up on the tool and bends it at the chuck. The parts are 1" long and I chuck it as close to that as possible. If I take two or three passes I can get some of them finished. I was thinking I would be able to do them in a single pass... I need them turned down just enough to fit inside some brass tube. Not sure there is any better method of I am just stuck making several light cuts?
I am stuck with reducing the size vs using a stock size because of the parts they mate up with, otherwise I would use tube and shaft that matched.
Jim
Jim
