- Oct 4, 2016
- 7,164
I have gotten things quiet, but the part looks distressed. My mystery 1.25 wants ~ 200 rpm, slow feed otherwise it starts singing, I could probably up the rpm as it progresses, as it gets quieter, but still looks smeared.
The 1" 12L14 can go a bit higher rpm, but ~300-350 has the better finish, something sounded bad, and went away on the picture. The center is how the other cuts looked. Center height, and squareness were adjusted over several cuts for both materials. If it's off the choir is in full song. The blade is an Empire P2 N, I tried low rpm, higher feed, and higher rpm, slower feed. There were several aborts trying these. I'm not sure how the face is supposed to look, so here is what I got, I'm adding oil as it's turning.
