G
gapi
Forum Guest
Register Today
On a new job I have fell into a shop of goodies that need TLC. I need help.
I'll start with the BP mill.
I had to replace the Hi-Neutral-Lo selector arm, repairing wiring and replacing the fuse holder in the the X-axis auto feed. She is good.
The Y-axis will not respond. The fuse is OK in the box on the side of the mill but the power indicator bulb is gone and the socket is toast, and a preliminary test meter probe under the POT and Rapid Traverse shows we have voltage.
Does anyone have experience trouble shooting this Y-Axis for a bad motor or POT, or..........
Below are some pics. If you need anything else please ask. If you have a link to a manual
If I can get this I can move to the errors in the FAGOR Innova 20i-T 2 axis Lathe kit. Thanks!
