I've got a well-used Skinner/South Bend 6" 4-jaw chuck that came with my SB9 that works perfect for my hobby uses, but as I was aligning the lathe with a ground/polished bar the jaw wear/bell-mouthing was very evident. I've got about two thousandths wear in the first 1/4" of each jaw, leading to an odd pivot point when centering work. Here's an example with some .001 shim stock, one jaw removed for clarity.
I removed the jaws and on the face, it looks like there's a factory taper on the jaw face to bias the grip towards the front. Each jaw had about .002 rise from back to front, except mine drop back to 0 in the last 1/4 inch. As it's a 4-jaw independent chuck, and I don't have a tool post grinder, I clamped one jaw in the mill vise and indicated the jaw face flat. The wear on the jaws is very evident here:
As each jaw is independent, my thinking is I'll be able to take a light cut across the top of the jaw to true it up past the worn portion while staying within the case-hardening range, but I'll be ending up with a flat face instead of concave. To leave some concavity, I could cant the mill head and use a larger-diameter carbide end mill to duplicate the 1/2" radius in the jaw.
Has anyone tried this approach, and if so - how much reduction in grip is there with a flat jaw face?
