- Sep 10, 2020
- 52
Hello all. I'm trying to troubleshoot the TouchDRO axis calibrate function. It seems my pre-made adapter with micro USB ports isn't getting counts from the Absolute Plus scale. I don't know what "version" that would be, but it has the round 5.5mm? x 2.1mm? power plug.
Anyway, when I position the indicator to the 1st starting point, it says that it isn't getting or got less than the minimum 10 counts. This has happened on the 2nd reading as well, and once I actually got both readings and it calculated a value. I read here that the Absolute Plus count value is 2540, so I used that and my Bridgeport mill has, so far, X and Y axis DROs! Does anyone know why I'm not able to use the calibrate function?
I bought the Absolute Plus scales and the TouchPro adapter several years ago for a square column Rong Fu clone bench mill, but after several mills and now this Bridgeport, I'm finally trying to get this TouchDRO system running.
Thanks, in advance for any insight into this scale calibrate problem.
