- Apr 29, 2019
- 2,252
I have an old Tree 2UCR Mill. The sight glass is so dark on the inside that I can not tell the oil level so I have been over filling to be sure it was not under filled. This leads to oil leaking out thru the spindle and all of my work shirts having a horizontal oil line across the chest from oil slinging off the spindle.
The current sight glass is .875 Dia pressed in type. I can not find a source for a replacement, all of the readily available sight glasses are NPT thread mount. A 3/4 NPT could be tapped into the existing .875 hole but I am afraid of the chips that will end up inside of the gearbox. The other thought was to make an adapter that will press into the .875 hole and have a 1/2NPT inside thread. It woiuld be a fairly thin wall from the 1/2NPT to the .875 OD of the adapter so the sight glass may actually expand the adapter to help lock and seal it in place. It looks like I could start with a brass 3/4 to 1/2 brass bushing and the 3/4 thread should clean up completely at the .875 dia.
Anyone have a better idea or a source for a .875 Dia press in sight glass. I am hoping to do all of this without actually opening up the head if I possibly can.
