- Aug 29, 2016
- 857
We won't get into why I bought an old American lathe when I had banished all things Imperial (and Whitworth) along with all things pushrod from my stable thirty years ago. But I did, a South Bend 14 1/2 dual tumbler. The only thing in my defense is the lathe came with all of the stud gears for the metric kit, only missing the 120/127 transposing gear. No problem? Problem.
I had read that the lathe used an odd 14dp change gear set. I verified that the stud gears were indeed 14dp. No one, not even Boston Gear, lists 14dp. So the hunt went on in odd spurts and starts, usually when I needed to cut a metric thread. 14DP is tough. I looked at the math of going to 127/100. It can be done, but would require a different stud gear set. So I looked into doing the 37/47. I determined the diameter was too small for the gears to engage. The 63/80 might work, but again, it would require making all new stud gears. In 14dp.
Then in a different thread, we learned how to make gears in FreeCAD. Alright, here we go. Drew up the 120/127 gears, and went searching for someone that could print them. It didn't take too long to find someone that was willing to print from my CAD files. They wanted to use their own slicer, but didn't want involved in the actual design. Hot damn. Yea HAH. So off to the design I go. I pulled the idler gear off of the lathe to measure the bushing diameter, hub depth, and all that needed stuffs. Bore is 7/8, hub depth is 1 5/8. Going good, nothing hard here. But something doesn't look right. Something is just... off. I take one of the 14dp stud gears and roll it around the idler. It does NOT mesh.
This is something I have not seen in any of my diggings, not here, not PM. The SB 13, 14.5 and 16 all use the same gearbox ratios, the came 6TPI lead screw pitch, and the same tooth count on the metric transposing set. What I have not seen anywhere is while the SB13 is 14DP as often quoted, the 14.5 is 12DP!! You 16 owners are on your own. I would *assume* they would be the same, but.... There is a clue in the SB parts manual. The shipping weight ont he metric kit for the 13 is 73lb, the 14.5 is 121, and for some reason the 16 is only 65.
So my change gear set is from a SB13. And I'm back to square one. At first I thought about making the transposing gear and the 64 tooth gearbox gear in 14dp and just switching out the entire set as needed. And I could make a 24 stud gear and a xx tooth idler so I can just leave it at DP14. But that's not the way SB intended life to be. And I really didn't buy all this machining equipment to have someone ELSE make things for me. And I'm skeptical of plastic drive gears keyed to a shaft. I have a DRO equipped mill. I have a lathe. I have a dividing head. I have a large rotary table. I even have aluminum blanks of approximately the correct size. HHS 12dp gear cutter sets are available from China.com.... ought to be good enough for low speed lathe gears in aluminum. The math is simple. I have zero experience. Checkity check, we're good to go.
Next up, teaching the dividing head a new number. I've looked around for a cheap 127 reference. Ironicly, the one odd source I found was a late MGB starter ring gear. But alas I banished those from my garage thirty years ago (see above). It's looking like I am going to end up drilling my own index plate. Damn prime numbers.
