There should be a few used machinery dealers that would have electrical equipment and transformers near you.
There is a place called HGR I seem to remember in Ohio. I think.
-Mark
240-480 is a common size in industrial applications. It shouldn't be difficult to find one. One important issue to keep in mind is that whatever the rating of the machine at 480 volts will be double for the 240 volt feed. i.e. If the machine is rated as 10 amps, the line side will be 20 amps. Requiring a 25 amp minimum feeder circuit.
I live 10 minutes from HGR, place is great. They always have a selection of transformers, although small ones are less common than the big monsters. Worth taking a look if you are in driving distance.
