Tramming tool
Mgdoug3
Feb 2, 2020
149
I decided to make a tramming tool for my mill. I was able to the tilt down 0.001" and that's good enough for me. I turned down a 3/4" rod to 1/2" to fit a collet and then used a 1/2" end mill on the other end. Since I was too lazy to get my welder out, I drilled and tapped the shank. Next I took a 1/2" rod 6-1/2" long and turned down the end for my dial indicators to clamp on. Finished up by drilling a hole in the middle and bolting them together.
So far I have only used my mill to make parts or tools for said mill but I enjoying learning how to use the mill. In the near future, I see myself buying a DRO unit. One of those look really handy to have.
Thanks for the suggestion. I have a few rough spots so I figured the parallel bars would help. I can't feel only high spots luckily.
My son finally got around to winterizing the engine in our racecar, in the process of removing the rocker arms the noticed they had been hitting the spring retainer, this usually means the installed height has changed, indicating a possible valve issue. Everything else seemed OK but after finding .012'" end play on the crank we decided to pull the engine, time for a freshen up.
