I have a cheap milling/drilling machine.
I noticed the other day that the column was not square with the table.
I adjusted it to square.
I knew that this would effect the rest of the mill.
I trammed in the head front to rear. (close to zero).
Then trammed in the table right to left to near zero.
Checking the front to rear tram the head was about .020" out.
My question is ; Is the a sequence to tramming in a mill?
Thank you,
Dale
BTW, I have to use shims to square the column and square the table front to rear.
Thank you,
Dale
