Tramming a Bridgeport??
Rifleman1384
Jun 29, 2019
63
Good Afternoon All,
I am new here having only posted once in the NEWBIE section. What are the specs or what is being used as ok for tramming. I made myself a Tram Gauge that can be used from 3"-6", I'll post a pic below. I want to know what the spec's are or what is acceptable. I have 9x42 1.5 Vari-Speed with Kurt DX-6 and swivel base.
NOD (front to back), I get .0005 using the bed of the vise with the jaws open and my gauge set with the dial indicators 6" apart. On top of the vise either behind the fixed jaw and in front of the movable jaw I get under .001, using the top of the jaws I get under .001 and that's traversing the X handle to read across the top of the jaws or flat areas. On the table left of the vise I get consistently under .001 but much closer to .0005. The right side of the table to the right of vise is get closer to .001. What is good and what is acceptable??
Tramming the table (left and right), with the gauges set a 6" apart on the left side of the vise I get very slight movement between .0005 and .001 but under .001. Right side of the vise on the table I get .001 to .0015. I Shorten the gauges up to 5" apart and check across the fixed jaw on the vise and I get just over .0005. Again what am I looking for.
I did calibrate the gauges and set zero before starting.
Be patient, I'm learning but so far love all the info contained here and the help everyone gives each otherTram Gauge.JPG. Thanks, Steve
These specs are fine. It will be awhile before it's the mill tramming that limits your work.
.0005" is not enough to mess with,
BUT
Many times the issue is with the gibs of the knee to column being loose, or wear of the ways on the top and back of the knee, and/or the bottom of the table. Remember to think outside the box for all factors that can contribute to geometry that is not square.
I chased my tail for hours on a used Jet 9x49. The problem is, mills are mostly used near the center of their travels. As you move in & out of those areas you can't adjust everything to compensate. Do you checking with all but one axis locked. When you are doing something you want as good as possible do the same. A DRO will help you a lot. (forget the last, tenths, digit.)
Nice work on the dual gauge.
Regards,
Terry
