- Oct 14, 2014
- 2,115
I need to power a large pressure washer with my tractor 540 PTO...
Its a CAT 1050 pump. Takes 15Hp at 1000 RPM.
So I need to step up the RPM and I'd like to run the tractor at a bit less than wide open.
Picked out these two pulleys at surplus center. One is 18.75" and the other is 8.75 ". My main question, will this easily transmit 15HP? Can I get away with a slightly smaller samll pulley to step up the RPM a bit more?
Put another way, how does one calculate the HP rating of a pulley system?
