- Apr 28, 2014
- 3,592
I'm starting this thread hoping to generate a detailed blow-by-blow account of setting up TouchDRO with Ditron Glass Scales.
After the scales are up and running I plan on adding a tachometer to the setup, but for now going to keep it simple.
I'm not exactly sure of which controller to use, or how to put it all together.
I realize that it's one of the TI MSP430's shown on Yuriy's TouchPro page, but even if was forced to chose I wouldn't be able to tell you with certainty which one.
(I'm hoping Yuriy will jump in here and point out the obvious to me... )
I'm going to be using a 10" HP TouchPAD tablet that is rooted and flashed to Android v4.4.4 with a Kernel version of 3.0.101.
The HP is a pretty tough tablet and they can be had 'used' on Ebay for under $60.
The only caveat is that they might have to be flashed for Android.
I want to set it up so that I have the option of doing both USB or Bluetooth. Reason for this is I'm not
100% certain that BT will work properly when all is said and done.
I also have not been able to figure out how to connect the 9-pin connectors on the Ditrons to the LaunchPad.
I've been reading so many posts that I've hit overload and am not certain which way to proceed, and need some help. (as usual.)
