- Apr 4, 2013
- 884
Hi folks,
Yesterday I published a new TouchDRO build to the close and open testing tracks. The one in the closed track has already been approved by Google; the open track one is still in review and will likely be approved shortly.
This build is a "Release Candidate". If no further bugs are found, it will be promoted to production in about a month.
In addition to publishing this to the Google Play Store, I'm working on publishing this to the Kindle App Store as well. The app is 100% kindle compatible, so I just need to jump through some hoops to get it listed (create promo graphics, etc.). I might set a test track for it, or just go for a production release. Since there are no existing users that would be automatically upgraded, I'm a lot less worried about it (upgrade path is the last remaining thing that I'm still testing heavily).
There are two bug fixes in this build:
There is another bug report that is not addressed that is related to 2D and 3D sub-datums. The behavior is as follows:
This is, strictly speaking, not a "bug". I.e. the app behaves as designed. The reason the Z axis changes is that the 3D sub-datum (which was affecting Z axis readout) is de-activated, so the Z offset is cleared. A few people got confused by this, and I see their point. The problem is that changing this behavior is a HUGE change in how the app works and would take a pretty major change. I will keep this on the bug list, but for now there is no plan to fix it. I.e. it might just end up being a "documented quirk".
Lastly, on touchdro.com, the first item in the "Resources" menu is the "TouchDRO V3 Release Status" page that has all of the info on how to get access to Beta testing (open and closed track).
- The timeout in the calibration wizard was too short (10 seconds), and when the adapter is in idle state, it sends one readout per second. Since the wizard needs 10 samples, it would error out. The timeout is now increased to 12 seconds.
- Automatic sub-datum selection was not working correctly with low sub-datum density. It's now fixed.
- Create a 3D sub-datum
- Create a 2D sub-datum
- Switch to 3D mode
- Activate 3D sub-datum (the one that has Z axis offset)
- Activate 2D sub-datum
