- Apr 4, 2013
- 884
Good day, folks.
I published the new build of TouchDRO that has fixes for the bugs that were reported so far. (that is to say, I published it, but it might take 24-48 hours for Google to make it available). I've also change the "opt-in" process. My forum's email server is completely FUBAR (too many spam registrations), so I made a Google group and access to the closed test track is determined by membership in the group: https://groups.google.com/g/touchdro-alpha-testing. It's set to "ask to join" mode, so no need to email me separately, just mention in the "Reason for Joining" that you want to beta-test the app.
Once you join the group, you can access the test build here: https://play.google.com/apps/testing/com.yuriystoys.dro
Till now I've been asking people to do a clean installation of the app, since the upgrade path wasn't fully tested. As of this build straight upgrade should work.
To date, I've gotten two nasty bug reports (both are fixed) and a few cometic issues (also fixed), so the app seems to be performing pretty well. That said, it's still a "BETA" version, so if you end up using it for critical work, please be careful and double check the results.
Also, huge thanks to the brave Alpha testers. The first week was pretty bumpy, and I really appreciate your patience.
Finally, here is the start of the user manual: https://www.touchdro.com/resources/dro-manual/index.html. I added content for things that I though would be most relevant, but there is still a lot of stuff I need to add.
Regards
Yuriy
Regards
Yuriy
