- Aug 5, 2013
- 281
Love my new TDA-420.. Sure works great..
I bought a cheapola touch probe (same as Mark Presling uses) from ALIexpress
It comes with USB plug cable, with 3 open wires
I referenced 4- pin mini din configuration to make sure I was wiring to correct pins, and reference from touchDRO for appropriate pinout for Auxiliary connector 1. (Left most connector facing rear)
The probe 3 wires are: Red- 5V, Black - 0V, Yellow- "signal"
The led lights on the probe come on, and switch red/green when pressing the stylus.
I measured the yellow signal wire to ground, and it goes from 5v, then .2 volts when pressing the probe..
I configured in touchDRO to use electronic edge finder, and tried both NO, NC toggle.
However, touchDRO isn't seeing the "signal" from the touch probe.
Here's how I wired it:
TouchDRO aux connector1:
Pin1 - Black wire from probe (0V)
Pin2 - Red wire from probe (5v)
Pin3 - Yellow wire from probe (signal)
Any thoughts other than a defective touch probe?
thanks.
Dan
thanks.
Dan
