Dear Yuriy,
A feature enhancement suggestion: linear division similar to the "rotary division" feature that already exists for the rotary axis.
I recently had a job where I had parts with 3x pre-existing holes all in a line. I needed to add a number of evenly spaced holes in between. If I were able to locate 2x points (ie 2 holes) as references and then use a division function to select the number of points or spaces between the points, that would be a super handy feature, especially if it displayed on the graphical screen as divisions are entered to visualise the spacings.
Instead I did it manually: found first & last point, manually calculated the spacings required the grid feature.
It would be nice if you can use a negative step over/step over in either direction rather than just in the positive X & Y directions (eg to allow stepovers either side of a centre point for example).
Thanks for the great product. It gives me jot everytime I use it.
Regards
Steven
Regards
Steven
