- Sep 29, 2017
- 2,295
I had to make a 1.2m shaft for a customer and on the ends there had to be M14×2 holes 120* apart. In order to do that I had to make a toolpost drill holder,wich I wanted to make for a while anyway,so now I had to.I know this is probably posted before, but I feel like sharing.
I used 125mm×50mm×80mm stock clamped it in the 4jaw and drilled a 1inch hole offset so I can mill the other side to clamp in the QCTP, and then bored it to 26mm.
I then had to use a slitting saw to split one side.......mmmm,I don't have a slitting saw arbor,I do have slitting saws though(got in a batch of used tools), so I had to make one.......quickly. Talk about making tools to make tools.I must add that this is the first time I used a slitting saw and it went quite nicely.
Drilled,tapped and sunk holes for M8 allen cap screws to clamp two brass bushes in the holder,wich I made earlier. Did the mill work, but forgot to take pictures.
And this is what I had to use it for.
Thanks for watching.
