Toolmakers microscope
RWL
Does anybody have any experience with a toolmakers microscope? I spotted a Gaertner toolmakers microsocpe mis-advertised on craigslist as an optical comparator and bought it pretty reasonably for a long term project I have in mind. My lathe came with two chipped teeth (the tumbler was popping out of its notch) and I eventually want to repair those. I need to make a single point cutter and I anticipate using the microscope to compare the cutter to the existing good gear teeth.
Now having said that, the microscope is interesting. It tilts from side to side so that if you're examining screw threads, you tilt it to match the (pitch? correct term?) of the threads and can measure the angle of the sides accurately. The ocular sits on a large disk with a small ocular above it. When you look through the small ocular you can see a scale. On the back of the big disk is a knob. When you turn the knob the main ocular turns and the scale moves. If I had a lined reticle in the main ocular, I could line it up with one side of an angular component and measure the angle.
The X scale for the table is spring loaded. If your part is longer than the micrometer scale and move, you can place a block of known dimension (gage block?) to get greater movement of the stage.
The stage has a knob that will allow the stage to rotate a small amount. It isn't calibrated, so I presume it's just an aid to getting a part lined up with the lines that should be in the reticle (but sadly there aren't any lines or shapes in my ocular). Anybody got any spare oculars around with what looks like a scale, screw shapes, or varying sized arcs etched in them?
Lets see, what else. There is a glass disk in the stage so that a part can be back lighted, but there are also two small lights on either side of the objective so that the part can be lit on its surface.
I have a cleanup / reorganization project going in the shop at the moment, so I haven't had time to figure out what power ocular and objective I have, but the magnification is higher than would probably be useful for the intended use. For that matter, it's probably overkill for the intended use, but hey, it's a new toy and the price was too good to pass up. You almost never see these for sale.
Anybody else have one or used one? Any spare reticles or lenses around? Any advice to the new owner?
It isn't real until there are photos, so here is what it looks like before I've cleaned it up. With some better lighting tonight I discovered that there are crosshairs inside the ocular lens. One can be rotated in relationship to the other and there is a scale of 30º to 70º etched into the periphery of the reticle. This end of the shop is a mess. Like I said earlier, I'm in the process of reorganizing.
01 Side (Large).JPG 02 Front (Large).JPG 03 Objective (Large).JPG 04 Gaertner Makers Plate (Large).JPG
Very interesting instrument. Normally the reticle is placed at the focus of the occular. Take the occular out and
look if the reticle is missing and if there exists a ring holder for it.You can measure the diameter and buy a new
one from Edmund Scientific for example.Normally the instrument will accept various reticles, so someone has
not replaced it the Last time.In desperate situation you can make one.My two cents.
Ariscats
After I got a little better illumination, I discovered that there is a reticle in there. It's not in the ocular, but somewhere in the prism or just before it. I replaced some bulbs on the surface illumination today and discovered that one shines through a red filter and the other through a green filter. I wondered why until I looked at something through the scope. The one side of ridges was illuminated red and the opposite side green. It helped to make the high spots stand out.
Oooooooh, I want one of those!!!!! I guess I am a tool junky. I dont need one, but it would be a coo; addition to my ever growing collection. When I die, there is gonna be a hell of a yard sale. Momma will probably end up giving most of it away because there is so much hidden everywhere in all the nooks and crannies throughout my shop. No good storage space left unused, and I can always build more if I run out........
Bob
Interesting score.
I bought a nice Mitutoyo last summer, but it doesn't have the features yours does.
Hmmmm.... thought I had a photo
Mine looks like this (without DRO)
http://www.youtube.com/watch?v=Mbty0HIaDN0
One thing I intend to do is mount a digital microscope to the head so I can output to a screen.
Interesting score.
And then you can use a program like 'Bitrule' or 'Measure' and have all the reticles (or so) that you might need.I consider buying a cheap chinese
thing from DealExtreme with capability of measuring distance,angle,area and calibration.Such is technology!!
Ariscats
