So I watched Tubalcains video and decided to make this clamp this weekend.
I learned a lot, or maybe a little, but hoping you guys and help with some questions.
1) I tuned between centers some and found a couple times my work piece stopped turning. I was not feeding fast or taking deep cuts. I was using a live center at the tailstock and a dead center with a Morse taper reducer in the spindle. I did not pound the adapter in very tight but gave it a little tap. I'm not sure if it was the center that stopped or the reducer. Maybe I still need a dog leg?
2) I used a lot of oil. Stuff I had laying around ISO10. Do I need to pay better attention to the oil I use? Is there a good sight that tells me exactly the oils I should be using for certain applications and materials?
3) Tubalcain did not turn down his piece before knurling. Is this okay?
4) His finish looks so nice and mine looks dark and unappealing. I plan on polishing it when I get everything done.
5) I still have to make an outside radius. I have a rotary table I was going to use for the first time but realize I have no t-nuts that fit it. I also have hold down clamps but even if I made the t-nuts I couldn't use them as the bolts are to wide to fit down into the nuts. That might have to be my next project.
That's all I can think of now, thanks in advance.
