This is what I would consider a good start, this will get you up and running.
Disclaimer; I'm not endorsing these products, just showing them as examples.
From the Grizzly web site.
G1075 Clamping Kit for 1/2" T-slots, 58 pc.
G7156 Premium Milling Vise - 4"
G1646 12 pc. Precision R-8 Collet Set
G9756 20 pc. HSS End Mill Set
G9815 Thin Parallel Set - 10 Pairs
H5556 4 pc. Edge Finder Set, just the bottom one, you don't need the whole set.
H8263 Grizzly 1/2" x R-8 Keyless Chuck with Integral Shank
G3658 Grizzly TiN Coated 115 pc. Drill Bit Set
H5930 Grizzly 4 pc. Center Drill Set 60
G5728 Grizzly 60 5 pc. Countersink Set
There are a lot of vendors for these items.
Then comes the measuring tools if you don't have them. If you are on a limited budget, Harbor Freight is a good place to look, at least they have a pretty much a no-hassle return policy. There are a lot of other vendors also.
0-3 inch mics
6 inch digital caliper
6 inch scale
Combination square
Dial indicator with mag base
And then you get to start really tooling up you shop, you can never have too many tools.:whistle:
