Morning guys and yes I'm loss without a clue.Guys this mill is not on my bucket list but its what I have and I want to work within its limits so that I can increase my chances to have some success.I do have a small vise but nothing else.Reading the small print in the manual this mill has a #2MT so I would like to find a basic collet set(maybe a drawbar also) to where the end mill will not stick out so far,would a fly cutter work on this mill?I don't know the difference between one collet set vs another,so which one would you choose that has good holding power and can be release easy?Now,other than having a vise what are the opposition for holding work flat and on edge.On the Atlas mill,the table just does not have alot of real estate so I wonder whats out there for clamping?I did go to Jeffs website and there is I guess a holddown set but I think its mainly for the bigger mills.What about clamping for round stock such as shafts,or something like that?
One of my first projects is trying to make a shoulder cut(1/8x3/4) in a piece of flat bar stock 3/4x6"x22".So I would like to ask for suggestions on what to get or look for in horizontal cutters(do I need the cutter to be able to cut on the side as well as the top)
One more question,end mills that I look at some or 2/4 flute,guessing the the 4 would be a slower smoother cut but I'm also guessing that this atlas will be slow anyway.I don't have no parallels,or 123 blocks,so I'm really at the begaining.
Well will these questions should keep me confuse but will also help me get started,so if you can make suggestions ,maybe provide a link to your favorite spot or just pics of what you are using will help greatly.I'm not making anything for airplanes or spaceships just stuff for myself.Thanks---kroll
