Ok, first post, here I go with the dumb questions!
I've been in "tooling acquisition" mode lately to set my "workshop" up, centered on a 7x16 mini lathe . As a beginner, I bought a set of 115 jobber drills at a reasonable price with LMS. Reading on the forum, I'm realizing that I perhaps made a mistake as the drills have a black oxide finish while I will mainly machine aluminum, polymers and brass. I will of course process some steel from time to time but it won't be my primary material. I understand that black oxide finish could cause the drills to grab aluminum rather than cut it and it seems that the preferred bit finish should be "polished". I already went above and beyond my initial budget and am reluctant to spend again to get a "polished" set.
So, metal gurus, could my current bits (black) work with a lot of coolant/lubricant? I am not going to use these intensively but wonder if they could ruin a work.
Thanks for any answer.
