I have just ordered a Taig 2019CR-ER CNC ready mill. It's got an ER16 spindle and I will use a Consew CS2000 motor instead of the standard motor.
I will use the mill mostly for making aluminum parts for building other CNC machines (such as my P&P), parts for telescopes, parts for home brewing equipment and for making or modifying electronics enclosures. Most of the stuff I'm planning to make is small, but some is close to the work envelope of the machine. I think I will be cutting aluminum about 80% of the time with the rest being mostly plastics/mild steel/brass. I might occasionally use it for milling/drilling circuit boards as well.
What kind of work holding devices do I need? The Taig milling vice is included with the machine, but from what I've read it's not very useful(?) I'm thinking about a 75mm (3") screw-less vice because it should be able to hold most of the parts I want to machine without being too large/expensive. Is this a good size? Will I need more than one size?
I think I will also need something to hold larger work pieces. Should I get a clamping kit, a tool plate, both or something else? (Maybe making a clamping kit instead of buying it would be a good first project for the mill?)
Is a fly cutter or a face mill useful for a machine of this size?
What kind of end mills should I get? I'm thinking I should get mostly 2-flute HSS end mills because I think those will work best with aluminum and plastics. Maybe some 4-flute for steel? I think long end mills will be useful for pocketing etc., but will they bend to much? Maybe best to get different lengths? Straight shank or not?
I guess that for CNC mill with limited rigidity it's best to use smaller diameter end mills than I might use on a larger machine or on same same machine if it was manual, and just accept that it takes more passes? If you have a similar CNC mill, which end mill sizes do you use the most?
This ended up being much longer and with many more questions than I intended Any advice will be greatly appreciated.
