- Aug 3, 2014
- 47
Ok I'm trying to make a very simple part using a m10 1.25 x 50mm bolt it is a grade 8.8. All that needs to be done to it is face off the bolt head to make a flat surface in which I've been successful cutting it from 50mm long to 44mm and boring a 1/4" hole through the center which is where I'm having trouble. I have burned up 4-5 bits as of so far trying to bore the hole I understand that the 8.8 is a tempered bolt but there has to be a way to do this I imagine. I have an atlas 10f could the problem be spindle rpm, bit material, ect. I do not have the tooling or skill to cut metric treads in hex stock so that's out I'm still very new to machining in general and only have basic tooling. Any help would be great.
Richard
Richard
