- Jul 7, 2020
- 71
I am helping a new machinist who wanted a lathe in the worst way. I had an old, but still good Craftsman 101 6" laying around minus the compound and swivel base. Thought about Ebay, but those weren't in the budget so came up with the idea for a block to mount a small A2Z quick change I had lying around. No adaption necessary to the lathe so a compound can be added later if desired. I don't usually like these quick chsnge toolposts on small lathes, but mounted like this gives a substantial amount of ridgidity to it.
The post is 2 1/2 CRS x 1.200" high. The post hole is 1.250" diameter and about 5/8 deep. It is held in place with two 1/4-20 set screws set .187" above the base. I threaded the top 3/8-16" for the toolpost bolt. Just need to paint the base and surface grind the top and bottom.
