I am planning to make a broaching bar which is to be used for cutting keyways on my milling machine. Obviously, the bar should be as rigid as possible and yet easy to machine. After some searching online, I found that the Young's modulus for all kinds of steel are very similar. For example, 12L14 steel, which is the easiest to machine has a Young's modulus of 190-210 GPa. 303 stainless steel is 193 GPa. High-speed steel is 200 GPa. This is very different from my impression that high-speed steel is much more rigid. Am I missing something here ?
