I can't afford a tool post grinder but I want one. I've seen a few plans on the net and in back issues of the metalworking mags, but I'm still too lazy/busy/inexperienced to follow thru that way.
Am I right in thinking that it is just a grinder that has been adapted to lock onto my cross-slide somehow, and if I can find a sturdy enough one that sits at the right height then there is no reason I can't just modify its base to fit my lathe? Is a dremel-type tool strong enough? How about those cheap little 6" grinders I keep seeing at the flea for $10?
I'm sure the high $ ones sit on a rotating plate so you can play with all the angles, but for now I'd be happy with something that would let me touch a moving grinding wheel to the work without everything exploding into a thousand pieces.
Have you, your neighbor or coworker done this? Did it work?
Joe
Joe
