- Feb 15, 2024
- 74
I've been playing with the tool library on my mill, and have found that the when setting the offset using the "Synchronize" button, the Z-offset values are negative, when they should be positive, and vice-versa.
If one tool is shorter than another, you have to move the mill in the negative direction... This means the actual tip of the tool is higher (positive) in space.
