It's a Viking. Best you could by at the time. Useable throat height is 9 inches. Been looking for one this big for quite a few years and this one showed up 2 miles from my home in a Cabinet Shop.
Billy G, I'm curious about the collets -- how do they work? Are they like a regular split collet that closes around the shank or more like a dedicated holder? Just wondering...
The tap slips in and a screw holds the tap fast. Slip the collet into the spindle. It fits into a slot inside the spindle to keep it from turning. Bring the spindle and tap down to the work and turn the wheel at the top backing off once in a while to break the chip. VIOLLA perfectly straight threaded hole.
Wonderful, thank you. I cobbled one together some time ago but the weak point of course was my tap-holding (drill chuck) mechanism. Was wondering how the real ones worked. Thanks again.
I really like the handles sticking out on the outside of the rim. Those would give you plenty of leverage on larger taps, the assembly would give you plenty of support to not worry about crunking on the tap off-axis. Reminds me of a fly press. Spin that thing down, keep your thumbs the heck out of the way, and watch it bend 1/4" plate like butter. Excellent score! Clean and shine it up, then show us how it powers through a 1/2x13" tap like butter.
