- Nov 14, 2016
- 3,289
I'm getting started on a small steam engine kit, and it involves some turning operations on hexagonal brass stock.
Obviously this will involve interrupted cuts so cuts need to be light until round is reached. Just wondering if there was any other advice.
The kit assumes a mill is not available, but as one is, for the pieces with a mostly round section and just a small hexagonal area it seems like it might make more sense for me to start with larger diameter round stock (easier to turn), and use a collet block to create the small hex section.
Looking in the Machinery's Handbook it appears a hexagon can be made from the same diameter of round stock (so 1/2" round stock can be used to make a 1/2" hex), is that correct or would it be advised to go up in size a pinch?
