- Mar 22, 2014
- 870
I need to press fit two .250 pins into a 12L14 part. The pins are W1 drill rod, not heat treated.
I did a test piece using a scrap of 12L14 and a ".249" reamer. The hole seemed to be slightly undersized, about .2485 I think, based on my pin gauges. I was able to press in the pin but it took an enormous amount of force. My small arbor press did not work. I had to squeeze it between the jaws of a large vise. I'm afraid I will damage the 12L14 part if I use that much force.
Are there any tricks that would help? Should I put a lead-in on the pin? If so, what angle and how long? Should I lubricate the pin and hole prior to pressing? Should I polish the pin? This is a one-of-a-kind part, so I could turn down the pin diameter, but I'm afraid it would be difficult to get the diameter just right.
