- Jan 6, 2017
- 1,248
The spindle bearings in my 2002 era Birmingham Chinese lathe are still humming along fine, but I sprung a oil leak in the gasket right behind the d1-4 mount.
I knew ahead of time that I would need to completely remove the spindle to access that gasket.
My current spindle bearings (SG, Phillipines) are fine, with about .0003" runout indicated off of a dead center in the spindle taper, but I decided to order a new set anyway, to have in-hand just in case I saw something I didn't like while i had it apart.
I found and ordered a set of Timken P5 bearings (made In Poland) from a reputable dealer in France. They look good, but there are no markings indicating the P5 rating, other that "P5" hand written on the box, in ink. There is no mark to indicate the side with max runout.
These sound legit? They weren't cheap. Timkens plethora of 100,000 page .pdf catalogs may as well be written in Klingon.
I can't find anything, in any of them, to indicate how to find a bearings accuracy rating in the part# marked on the race. Given the size of their .pdf catalogs, I'd need a couple million years to read through them with any kind of thoroughness.
