I realize this topic has been rehashed so many times but something is bothering me.
Recently, I've had my 10F headstock disassembled and took a look at the Timken bearings at that time.
Removing the press on dust covers, then pressing out the bearings, I took a look at how the oilers are configured. From what I could see, the oil actually drips down along the *side* of the bearing to the bottom of the bearing cavity. Unless the oil pools at the bottom high enough to flow onto the bearing rollers, I don't see how the bearings are actually getting oiled. At least that is how it looks to me. Am I missing something? If so, I need some help understanding. It sure seems to me that you would need to flood the oil cup to get enough oil down to the bearing to do any good. I keep seeing references to people putting felt into the oil cups to provide filtering as well as regulate the flow of oil into the bearing cavity. However, this also seems to contradict logic if my observation is true.
I would appreciate someone setting me straight on this. If anyone has a pictorial to share that would help highlight the proper oiling operation, that would certainly be appreciated.
Thanks for listening - Jim
