- Mar 11, 2018
- 9
I'm in the middle of swapping my babbit headstock with a timken headstock (10A-2B). The timken bearings are very tight fit on the spindle. The spindle came with the main bearing (closest to the bull gear) already installed. When doing dry fit assembly, the bearing on the opposite side will only slip on over the threads, once they get to the smooth part of the spindle, they stop. Should the bearings be press fitted? I'm cautious to apply force or slight tapping with mallet, I need to be able to remove them for the actual install in the headstock. All other components, gears, pulleys, and collars easily slip into place without force.
appreciate any advise...
thanks,
Jude
thanks,
Jude
