- Mar 26, 2013
- 29
In my 10EE CNC conversion I have decided to go to either a type L (.375 between teeth) or type T10 (10 mm between teeth). I think I will need the belts to be heavier than the XL that I used on my Millrite conversion because the apron drive will require 12 inches between the pulleys.
Does anyone have any reason for picking the L series over the T10 or vice versa due to cost, availability, load capacity etc between the two either for the belts themselves or for the pulleys.
I have done a little googling on the subject but can find no direct comparisons of the two. If anyone has positive or negative experience with either it might save me time or money down the road.
Thanks,
Cecil
Thanks,
Cecil
