- May 7, 2023
- 2,156
If anyone needs a manual for this machine you can download it here. Takes it a bit to download so be patient.
What is a Steinel mill?
Mine looks like this.
This is where it sits as of now. I had to drag it out of its hidey hole to work on it so I figured why not go ahead and chronicle the work Im currently doing on it. Maybe doing so will give me the needed drive to finally get it fully working and fitted out for use.
I got this mill cheap probably 25yrs ago. I've worked on it enough to use it occasionally but its in no shape to do any real fine work with. I havent even been able to oil it for use as, well, Ill get to that in a minute. It has had some strange things done to it in its life, but that is not necessarily a bad thing as the mistakes of others made it inoperable which saved it from wear and is also how I got it so cheap. Its almost like it traveled through time untouched for 40yrs.
IIRC I paid $250 for it.
I believe this was made in the early 70s, possibly earlier and from what I understand it saw limited use in a Tool&Die shop. Its a nice little machine that does not take up much space, but its no where near as versatile as a Bridgeport or other common mills.
So to the the history of this as I understand it and why it has not seen much use by me or anyone for 40yrs. The place I bought it from bought it from the Tool shop to use in their lil mom&pop outfit. Somehow they had the idea that the oil zerks on this machine were actually grease zerks and pumped the whole damn thing full of grease.
An Oil zerk looks like this.
Vs a grease fitting
Main difference is a grease gun fitting wont snap on to an oil zerk.
Given that, they really really had to put some effort into this lubricating venture as the entire damn thing was stuffed so full of grease it wouldn't work anymore. Seriously, I kid you not. It seemed they thought that if greasing it didn't make it work better, than more grease would surely do the trick. They used the old school ropy wheel bearing grease too, not some slippery new age type of lubricant.
Over time the grease they stuffed it with did what grease likes to do and blead all of the oil out of the carrier medium. You may or may not know this, but grease is just oil in a carrier medium that holds it in place. Sometimes the carrier is clay, sometimes its a fancy polimer. In this case I can only figure the carrier in this grease was wood dust.
The entire machine was full of what appeared to be wood that took the form of every nook and cranny. It stopped the gears from turning, the ways from waying and worst of all, broke the gib screws rendering it useless as a milling machine.
I spent the first 3 months of ownership disassembling it and carving all of this oak like dried grease out of the majority of the machine with wood chisels, a small hammer and scribers.
The next thing I did was convert it to a 1hp DC motor and drive which you can see in the pictures. This is actually the 2nd drive Ive had on this as I had my pully ratio way off and trying to mill something in the dead of winter (You seriously have to let this thing warm up in the cold temps) put too much stress on it and it let the smoke out of the driver board.
With the setup as it is now I get variable speeds from 0 to 1000rpms, or higher with the change of a belt and buckets of torque at all speeds.
I hadn't touched this in a longtime as far as fixing it, but then last weekend I stumbled across a lost part for it in a box and I was off to the races. I had bought some Igauging scales for it, but so far only mounted the reader displays as this mill was made before DROs were common so theres no readily available mounting surfaces for them.
Anyone familiar with this machine may notice the quill handle is not the standard one that came with the machine, but more like the multi position types you can buy for Bridgeport's and such. This machine came with a quill handle that was on a locking taper, so in order to change the handle position you had to loosen the nut, smack the nut with a hammer to break the taper free, reposition the handle and retighten the nut.
Total pain in the ass!
So I made my own multiposition handle and its friggin sweet!
Here it is next to the stock handle. I think they intended lifting battleships or breaking rocks with the standard handle, maybe they had too much metal? Who knows.
The end of the handle where the taper is must weigh 3-4lbs, you could bludgeon an OX with this thing.
For those unfamiliar, this handle lets you go from this:
To this:
On the fly In under one second.
Side note, I probably should have cleaned the lathe before taking these pics. Its sort of a catchall and another totally different long term project in its own right.
Some pics of the handle parts in the making.
Notice the rust? As I mentioned in a different thread, Government work has to wait until there is a slow day, or in this case several slow days over the course of a couple months.
Finished parts after heat treat.
Steinel SV4 Manual and Flier.pdf
onedrive.live.com
Vs a grease fitting
To this:
