- Jul 22, 2019
- 33
I would like to buy a tilt table or sine vise. I have one immediate use in mind. I would like to make a steady rest for my mini-lathe that would let me use a piece of wood to steady the material. I was thinking that I could take a piece of 3/4 inch or 1 inch square bar, and machine a 45 degree notch to engage the ways, and then drill holes so I could take a random piece of wood and use it as a steady rest. I would have to slide this wood steady rest into a drill mounted in the chuck, not 100% sure how well that would work. I have the cast iron steady rests, one for one inch diameter, and one for two inch diameter, but they tend to leave grooves in the work, and I would like the option to turn something larger than 2 inches.
I don't really understand why I would choose a tilt table vs a sine vise. The sine vises that I have seen look kind of flimsy. I would think that I could clamp the work onto the tilt table, but maybe I would be better off with a small vise mounted to the tilt table. The tilt tables are pretty reasonably priced, I think around $75. The sine vises may use gauge blocks, which I do not have. Not sure that I could use a sine vise to make this part for a steady rest, unless it was a very large (and expensive) sine vise.
I have a mill drill, not a mini-mill. It is a Harbor Freight, maybe a 9 by 28 inch in terms of table motion. I think that it weighs 700 pounds, so a lot more substantial than a mini-mill. I have had the mill-drill and mini-lathe for a while, have used them some, but still think of myself as a beginner.
I think that I might be able to use a chamfer mill bit, since I think that my project would only need a 45 degree angle. But it might make more sense to buy a tilt table or sine vise, and have something that I could use to mill any angle.
Thanks in advance,
Richard
Thanks in advance,
Richard
