- Apr 28, 2016
- 86
I'm on the fence between ordering a 255EXT (250A) and a 350EXT (350A), as the cost difference on AMZ is currently $550. I've already got a MIG machine at home so I'd like to try to end up with only TIG box.
The 255EXT is dual voltage (which is nice to have but not a requirement) and goes lower on the amps: 3A DC / 5A AC vs 5A DC / 10A AC . The 350EXT has a 30A higher 60% duty cycle and, obviously, higher max amps. The 350EXT also has slightly higher max voltage. I suppose the 350EXT probably has higher startup inrush current, which might be an issue on a generator (not a concern for me). The 350EXT comes with 18 & 26 torches instead of 20 & 9; I expect those will be promptly replaced either way anyways.
Perhaps a way to look at value is in terms of $/A.
255EXT - $9
350EXT - $8
I do occasionally want to weld 1/2" SS and mild steel plate but most of my projects are in the sheet to 1/4" plate range. Ignoring cost, if you could have only one, would you choose the lower minimum amps or the higher max amps?
255EXT - $9
350EXT - $8
