I just got a crap load of different diameters of steel tig rod. all are 70rs. whats special about tig rod ? is it purer than just normal gas welding rod ?
Hi, TIG filler rods are usually triple deoxidised, that is they contain additives that produce a better weld. Gas rods usually don't have these additives. The copper flashing helps stop corrosion but the really hi tech stuff doesn't even have that because of the contamination it would cause, that stuff you find specified for aircraft welding and the like.
Regards, Dave
That's solid info!!
Thank you,
Daryl
MN
