Good Morning! (Or Perhaps Evening?)
Please pardon my tooling ignorance. I'm learning as I go (and go, and go, and go).
Many years ago I bought a neglected 13" South Bend 34-BQ lathe and it came with many boxes of mystery parts. Today I stumbled upon 3 items I had forgotten about (mixed in with some chuck jaws for unknown chucks and a few half Lovejoy couplings).
I'm wondering if any of you all recognize the items in the attached photos & don't mind sharing your expertise. (Assuming I actually succeed in attaching photos. I'm from the pre-computer era so things often go wacky!)
All three items are made of an 'unknown-to-me steel' alloy.
The short item on the left is 1.75" diameter and 0.825" tall. The bore is 0.750" The tapered portion is 0.140" tall.
The item on the right looks to me to be a simple flanged bushing, but I wanted to be sure it is not an important piece of tooling (before I use it for something else). It is 2.00" tall, 1.975" large outside diameter & 1.250" small portion outside diameter. The bore is 0.671". The flange is 0.484" thick (or 'tall'?) There is a hint of green paint on the flange.
The center item looks like it may be a collet adapter for a spindle. (Just guessing from my research)
It is 2.611" tall. The flanged part is 0.464" tall. The diameters are 2.877" flange, 1.675" body before the taper and 1.416" at the smallest OD of the taper. The bore ID is 1.266"
The larger holes are through holes. They are 0.535" diameter.
The smaller holes are threaded to accept 3/8-16 & they go all the way through.
There are no markings regarding a part number or manufacturer on the tool.
It is the holes that have me confused. I wonder if it is for holding collets in a special jig, or if there is an actual spindle that it is meant to be applied to. I looked at as many spindle adapters I could find without finding a similar item, so perhaps I am running down the wrong road.
I am hoping you all may recognize these items, or perhaps point me in the right direction for further research. I love to learn and these have me truly stumped.
Thanks Much & Enjoy Today!
Paul
Paul
