I needed to make a few treaded studs 2-56 for a model engine I'm building. The Machinery's Handbook tells me for a external thread , major diameter the max is .0854 and the min is .0813. I turned my stock to .082 and couldn't get the die to even begin to start. At .081 with die started cutting. Two questions: 1- Is the major diameter used only when single point cutting? 2- Is there a rule of thumb on how much smaller to turn material when using a die? Thanks for any light you can shine on this. Roger
