Hi all.... I have drilled and bored a hole to an inside diameter of 20mm and then threaded it. I now need to make a threaded plug to go into this opening. I'm wondering....do I make the diameter of the plug the same as the opening that it's going into or should I make it slightly larger so I can sneak up on a nice fit when I thread it? Thanks
